RE: [Nagios-devel] Disable host checking ?
> -----Original Message-----
> From: Marco Borsani [mailto:[email protected]]
> Sent: Wednesday, March 23, 2005 10:40 AM
> To: Marc Powell; [email protected]
> Subject: R: [Nagios-devel] Disable host checking ?
>=20
> My doubts are regarding to other actions which can be performed via
CGI
> - enable/disable notifications
> - enable/disable event handler for this service
> - ... and so on !
>=20
> Probably you have answered me in the last mail ... all the changes are
> made
> internally and in the status.sav file.
> Moreover you conferm me that Nagios does not modify the configuration
> files.
>=20
> Is all correct and enought to understand how nagios work (for this
> argument!) in your opinion ?
Yes, I believe you've got it. The same behavior applies to both your
examples above.
Marc
