Re: [Nagios-devel] [Nagios-users] Nagios client merge NSCA/NRPE
This idea is fascinating to me -- using a messaging system to return
passive check results. This would
- allow larger messages
- allow for multiplexing of checks into a single message if the Nagios
server side agent (the program that pulls messages off the queue and
turns them into check results) knows how to do that
- provide a nice way of handling check results if your Nagios server
goes offline (they'll queue up in the messaging system)
- you could potentially even do Pub/Sub with check results to allow
multiple Nagios server to "subscribe" to particular check results
- I would think you could just write some kind of simple program that
could be called on each platform (kind of a send_nsca equivalent) that
sends results to the messaging system. It's more overhead, but most
prominent messaging systems can use JMS which could make the message
layer mostly vendor agnostic
I too have struggled with NSCA but in my case, it's about sending output
from my distributed servers to the central server(s). I ended up having
to write my own send_nsca batching-daemon to transfer more efficiently
(and reliably). I have 2 running -- one to send to my primary Nagios
server and another to the backup.
Mark
>-----Original Message-----
>From: Hans Engelen [mailto:[email protected]]=20
>Sent: Tuesday, November 04, 2008 10:12 AM
>To: [email protected]
>Subject: Re: [Nagios-devel] [Nagios-users] Nagios client merge=20
>NSCA/NRPE
>Slightly confused on what it is you need here.
>Personally I never really liked NSCA, as for NRPE it's better but
>still has issues (such as manual work is needed to configure and set
>up the checks on the remote end). I think this is similar to what you
>are saying.
>I must admit I have been playing with some ideas along those lines
>myself lately but for me the more urgent priority was to get NSCA out
>of the mix. I chose to go with an EMS (enterprise messaging system) as
>my means of communication. Currently I have a few passive checks
>running as that. Because of the somewhat exotic software we have
>running I usually end up coding my own passive checks and I wanted to
>get rid of having to fork out to send_nsca. The main reason being that
>I needed more feedback on the actual submission of the check results
>(loosing the check results on something that runs but once per day is
>a pretty big thing for me) to make sure the submission was successful.
>As such I am currently using IBM Websphere MQ to handle the messaging
>back and forth.
>Next on my list was NRPE, although I am still thinking that through
>since there is far more to take care of. Part of that would be pushing
>out updated plugins to the remote host.
>By the way, why IBM Websphere MQ, simple, it has api's for almost
>every programming language I use (in fact all of them).
>On the Nagios side I am currently using a fairly simple perl script
>(currently cronned) that feeds back into the external command file
>though I might go with an actual module that hooks into the nagios
>process later if the need arises (although I don't really want to if I
>can help it).
>Cheers,
>Hans
>On Mon, Oct 20, 2008 at 3:02 PM, Bo Philip Larsen=20
> wrote:
>> I need to find a client to use with nagios, it should be=20
>using passive
>> communication like "nsca", it also should use standard=20
>nagios plugins and be
>> configured with an nrpe.cfg like syntax it would be nice if=20
>each service
>> check could be scheduled individual in the client configfile=20
>without using
>> cron.
>> The client will be used on various *nix systems
>> Does anyone know if that type of client exists or have=20
>anyone a clue or
>> interest in developing this ?
>> The background: we are using nagios in a distributed network=20
>with nrpe on
>> 1000+ hosts and a company merges have given us 2000+ hosts more using
>> various monitoring systems like bigb using passive=20
>communication and the
>> active communication is on an option for now. We are using nagconf
>> (http://nagconf.naguser.dk) as configt
...[email truncated]...
