Re: [Nagios-devel] Do not launch a shell for each check
Hash: SHA1
On 10-10-03 10:53 PM, Ethan Galstad wrote:
> Ton Voon wrote:
>> On 29 Sep 2010, at 12:36, Matthieu Kermagoret wrote:
>>> On Tue, Jun 1, 2010 at 3:49 PM, Matthieu Kermagoret
>>> wrote:
>>>> The patch I propose, handle simple commands with shell quoting
>>>> (simple
>>>> and double quote). Every command containing any of these characters
>>>> (escaped or not) will be handled by the shell --> !$^&*()~[]|{};?`
>>>> So any feedback on this new proposal ?
>>> Could it somehow make it into HEAD ? It would resolve issue #86.
>> Is it possible to get some libtap tests running against these?
>> If so, I'd be happy to review what you have done in the tests.
>> However, this is quite an intrusive change, so would have to go into
>> the next feature branch.
>> Ton
> Agreed - Nice idea, but it should probably wait for a 3.3.x release.
> Once I release 3.2.3, I'll create a 3.2.x branch and this can get
> committed to HEAD.
FWIW I've suggested something like that for a long time but never got
around coding it. I think we should use a different command type (i.e.
two possible command line option, either one of them and never both
would be required). Just like for command arguments, they could be
separated with "!".
For example take my (slightly complex) SNMP load average command:
> command_line $USER1$/check_snmp -H $HOSTADDRESS$ -o .1.3.6.1.4.1.2021.10.1.3.1,.1.3.6.1.4.1.2021.10.1.3.2,.1.3.6.1.4.1.2021.10.1.3.3 -w $ARG1$ -c $ARG2$ -C $USER5$ -l 1min: -l 5min: -l 15min: -l Load -D ", " -m UCD-SNMP-MIB
It could be rewritten as:
> command_exec $USER1$/check_snmp!-H!$HOSTADDRESS$!-o!.1.3.6.1.4.1.2021.10.1.3.1,.1.3.6.1.4.1.2021.10.1.3.2,.1.3.6.1.4.1.2021.10.1.3.3!-w!$ARG1$!-c!$ARG2$!-C!$USER5$!-l!1min:!-l!5min:!-l!15min:!-l!Load!-D!, !-m!UCD-SNMP-MIB
This also allow passing empty arguments and doesn't require nagios to do
any single/double quote parsing, which could break some complex command
definitions (that would likely be much easier to write in the _exec form
anyway...)
And I think the same would be beneficial for NRPE as well, allowing at
the same time to safely pass arguments using the exec form...
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkypWRIACgkQ6dZ+Kt5BchZngQCg3CfjajrI9scS+9KFJkTExsSd
eAoAoJfIwJ7djwriD3a+ZpYok4fv0p4W
=B9OE
-----END PGP SIGNATURE-----
