> On 10/23/2010 11:33 AM, Andreas Ericsson wrote:
>> On 10/23/2010 12:21 AM, Mathieu Gagné wrote:
>>> Tests are both resulting in the same errors and failures.
>>> Am I missing libraries or did I miss steps?
>> I've moved code around and not catered to Ton's tests when I went on my
>> reorganization spree, so it's likely that particular tree is broken wrt
>> testing.
>> I'll see if I can get around to fixing it today.
> Well, lo and behold. Tests run just fine for me now, and I managed to
> push the outstanding patches to the public CVS stuff. I even found a
> bug I'd introduced thanks to Ton's awesome tests
Bleh. I spoke too soon. Fix coming up in a couple of minutes.
OP5 AB www.op5.se
on peace.
