[Nagios-devel] ndoutils 1.4b7 bug?
After searching and posting to forums I've yet to find anything on
this error so I thought I'd post up here.
When using ndoutils 1.4b7 on both the 2.x and 3.x releases, I get the
following error(s) on Nagios startup:
Feb 6 05:55:07 10-0-0-19 ndo2db-3x: Error: mysql_query() failed for
'INSERT INTO nagios_configfilevariables SET instance_id='1',
configfile_id='1', varname='cfg_file',
varvalue='/usr/local/nagios/etc/objects/contacts\.cfg''
varvalue='/usr/local/nagios/etc/objects/timeperiods\.cfg''
varvalue='/usr/local/nagios/etc/objects/templates\.cfg''
varvalue='/usr/local/nagios/etc/objects/localhost\.cfg''
I confirmed that this issue only shows up in 1.4b7 (I tested with
1.4b4-1.4b6). Just going through the differences in 1.4b6 vs. 1.4b7 I
found this change in dbhandlers.c in 1.4b7:
if(asprintf(&buf1,"INSERT INTO %s SET %s"
,ndo2db_db_tablenames[NDO2DB_DBTABLE_CONFIGFILEVARIABLES]
,buf
,buf
)==-1)
buf1=NULL;
whereas 1.4b6 uses:
if(asprintf(&buf1,"INSERT INTO %s SET %s ON DUPLICATE KEY UPDATE %s"
,buf
,buf
)==-1)
buf1=NULL;
To test, I just "patched" a 1.4b6 tarball so it was up-to-date with
1.4b7 BUT left the above section untouched. Doing this seemed to have
stopped the errors from showing up on startup.
Is this an actual "bug" or did I just do something wrong? If it is a
bug, is it safe to use the chunk of code from 1.4b6?
Eujon
