--0015175d03583cf28b04ca2fde1c
Content-Type: text/plain; charset=ISO-8859-1
mm. something else is wrong, I see that it did the file before getting to
xodtemplate. will debug more
On Thu, Sep 20, 2012 at 10:23 PM, William Leibzon wrote:
> This did not fix CGIs, those would bypass trying to read main config file
> and try to go directly for default cached objects file. This is
> in xodtemplate_read_config_data and in addition to that issue macros are
> wrong there with #ifdef NSCORE inside #ifdef NSCORE.
> On Sun, Sep 16, 2012 at 2:32 PM, Andreas Ericsson wrote:
>> On 09/16/2012 05:13 PM, Joerg Linge wrote:
>> > Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
>> >> Well, that's by design. The objects.cache should only be written to
>> once.
>> >> Or do you mean that it gets created but is empty?
>> > Correct.
>> > object_cache_file was created using the wrong path
>> (/usr/local/nagios/var/objects.cache as defined in includes/locations.h
>> instead of /omd/sites/ng4/var/nagios/objects.cache defined in nagios.cfg )
>> > But the file contains just the header.
>> Righto. I figured it out and a fix is pushed to both github and to
>> svn. Thanks for helping out.
>> Andreas Ericsson [email protected]
>> OP5 AB www.op5.se
>> Tel: +46 8-230225 Fax: +46 8-230231
>> Considering the successes of the wars on alcohol, poverty, drugs and
>> terror, I think we should give some serious thought to declaring war
>> on peace.
>> Everyone hates slow websites. So do we.
>> Make your web apps faster with AppDynamics
>> Download AppDynamics Lite for free today:
>> http://ad.doubleclick.net/clk;258768047;13503038;j?
>> http://info.appdynamics.com/FreeJavaPer ... nload.html
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
Content-Type: text/html; charset=ISO-8859-1
mm. something else is wrong, I see that it did the file before getting to x=
odtemplate. will debug moreOn Thu, Sep 2=
0, 2012 at 10:23 PM, William Leibzon <[email protected]>=
wrote:
This did not fix CGIs, those =
would bypass trying to read main config file and try to go directly for def=
ault cached objects file. This is in=A0xodtemplate_read_config_data and in =
addition to that issue macros are wrong there with #ifdef NSCORE inside #if=
def NSCORE.
On Sun, Sep 16, 2012 at 2:32 PM, Andreas Eri=
csson <=
> Am 16.09.2012 um 16:27 schrieb Andreas Ericsson <[email protected]>:
>> Well, that's by design. The objects.cache should on=
ly be written to once.
> Correct.
> object_cache_file was created using the wrong path (/usr/local/nagios/=
var/objects.cache as defined in includes/locations.h instead of /omd/sites/=
...[email truncated]...
