Re: [Nagios-devel] MAX_PLUGINOUTPUT_LENGTH
On Wed, 27 Aug 2003, Thomas Soupault wrote:
> Hi all,
> I would like to know what do I risk if I recompile nagios with a greater
> value than 352 for MAX_PLUGINOUTPUT_LENGTH ?
The result is platform specific. 352 is the lowest common denominator for
maximum pipe buffer size. Using larger values can cause data from
different plugins to be interleaved - and then none of the data would be
understood...
-sg
