Dirk De Coninck wrote:
> Hi all,
> First I would like to thank the Nagios developers for providing us this
> wonderful tool and sharing it with the community.
> I am using Nagios 2.2 and there seems to be a bug when using escalation
> overlapping with different notification intervals.
> What I want to achieve is this:
> For all service and hosts notifications an email is to be sent to the
> system administrators list with a notification interval of 20 minutes.
> When a critical or down notification (not for warnings) is not
> acknowledged within 20 minutes an email should be sent to the managers
> list.
> The managers only want to get 1 notification to report the critical or
> down state and a recovery notification whenever the status is recovered
> but only for recoveries that they initially got a notification for.
> To achieve this I created the following escalation definition templates:
> define serviceescalation{
> name mgmt
> first_notification 2
> last_notification 3 ; if I put 2 here, they never get the
> contact_groups mgmt
> notification_interval 0 ; if I put 20 here, they get 2
> critical notifications and no recovery
> escalation_period 24x7
> escalation_options u,c,r
> register 0
> name admins
> first_notification 3
> last_notification 0
> contact_groups admins
> notification_interval 20
> escalation_options w,u,c,r
> register 0
> define hostescalation{
> name host-mgmt
> last_notification 3
> contact_groups mgmt
> escalation_options d,u,r
> register 0
> name host-admins
> last_notification 0
> register 0
> All hosts and services have the admins as contact group with a 20
> minutes notification interval.
> First I tried only adding an escalation entry for the mgmt group (worked
> fine in version 1.3):
> use mgmt
> hostgroup_name internet-servers
> service_description PING
> use host-mgmt
> The result is that I get the first notification to the admins and 20
> minutes later I get the escalation notification to the mgmt and then
> nothing anymore.
> Then I tried adding an escalation for the admins:
> use admins
> use admins
> But no result either.
> The only way I can almost make it work is by changing the management
> template notification interval to 20 and setting the last notification
> to 2. The admins get the reminders this way, but the mgmt never gets the
> recovery notification.
> Just a thought, but what would make everything a lot easier is the
> possibility of defining first_notification, last_notification,
> notification_interval, escalation_period and escalation_options in the
> contacts definition (contacts.cfg).
> Since it is advised to work with templates to make things more easy, why
> don't the service definitions inherit most of the
...[email truncated]...
