Re: [Nagios-devel] Question,
Jochen Bern wrote:
> On 11/05/2010 05:30 PM, Michael Friedrich wrote:
>> 2. Is a patch from Nagios Tracker, I've slightly modified the Javascript
>> to fit into Icinga's index.html. Confirmed working on FF and Opera. If
>> that's what you are referring to - https://dev.icinga.org/issues/954 but
>> I am not sure if you are talking about the same as I am ;-)
> No, not quite - it's not identifying the *Nagios* the page comes *from*
> but the host/service/group it is *about*. Think "OK, the database is
> finally fixed - now where's that warning about our mailserver again?". A
> bazillion of tabs all called "Current Network Status" or "Extended
> Information" isn't giving you much of a hint for that.
> Or, to quote the sample-config/cgi.cfg.in part of the attached patch:
> # TAB-FRIENDLYS
> # Activating this option changes the of status.cgi
> # and extinfo.cgi when they refer to a single host, service,
> # or group. They will then read:
> # [Host]
> # {HostGroup}
> # ServiceDesc @ Host
> # (ServiceGroup)
> # These are easier to read and find if you use (many) tabs
> # in your browser.
> #tab_friendly_titles=1
reworked into Icinga CGIs (header has been modularized into cgiutils.c)
- works fine. Thanks for your patch :-)
Kind regards,
Michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
fax: +43 1 4277 14279
web: http://www.univie.ac.at/zid
Icinga Core& IDOUtils Developer
http://www.icinga.org
