Re: [Nagios-devel] More config file madness add intersection to
John Rouillard wrote:
> Hi all:
> Is 3.0 going to support the intersection operation between hostgroups?
> Currently you can do:
> web_servers,!boston
> to get web servers that are not in boston, but trying to get web
> servers that are in boston means adding every host to a site (e.g. boston,
> miami, london, orlando) and then:
> web_servers, !orlando, !miami, !london
> this is a maintenance nightmare when adding new sites and doesn't
> express what you want. (I chose a simple example here. In some of my
> configs I have 10 or 15 different hostgroups.)
> What I would like to see is support for the intersection operation.
> So web_servers in boston would be:
> web_servers, &boston
> and production tier 1 web servers in boston that are not dns servers
> would be
> web_servers, &boston, &production_tier_1, !dns_servers
> The addition of intersection provides all the standard operations of
> set theory: intersection, difference and union.
> -- rouilj
> John Rouillard
> My employers don't acknowledge my existence much less my opinions.
I don't have any plans to add intersection support, as it would increase
the complexity of the code quite a bit. You can accomplish what you
need by using smaller hostgroups (that don't get registered) that
contain distinct sets of hosts and then use the new subgroup feature in
Nagios 3 to define larger hostgroups that contain members of the smaller
groups you defined.
Ethan Galstad,
Nagios Developer
Email: [email protected]
