[Nagios-devel] nagios_services.host_object_id field missing after
this line appears to be missing from the upgrade scripts:
ALTER TABLE `nagios_services` ADD `host_object_id` INT( 11 ) NOT NULL DEFAULT
'0' AFTER `config_type` ;
Mike Conigliaro
ProActive Technologies
[email protected]
203.239.0440 ext:317
www.getproactivenow.com
This communication, including attachments, is for the exclusive use of addressee
and may contain proprietary, confidential or privileged information. If you are
not the intended recipient, any use, copying, disclosure, dissemination or
distribution is strictly prohibited. If you are not the intended recipient,
please notify the sender immediately by return email and delete this
communication and destroy all copies.
