Re: [Nagios-devel] Nagios3.0b4 Solaris9 compile issue
Great! Thank you very much Ethan.
-Dave
Ethan Galstad wrote:
> Found the bug - patch will be in CVS shortly...
> David Halik wrote:
>> It seems as though it's not limited to suncc. I just tried rebuilding it
>> with GCC 4.2.1 and it fails in the exact same way. No one else has seen
>> this whatsoever? Seems strange that it would fail in both GCC and SunCC
>> and yet be limited to only my system.
>> David Halik wrote:
>>> Does anyone have any clues about this? I still haven't been able to get
>>> past the use_large_installation_tweaks building issue. I'm guessing it's
>>> not apparent in gcc since suncc is much more strict. Any help would be
>>> appreciated.
>>> Thanks,
>>> -Dave
>>> David Halik wrote:
>>>> Hi all,
>>>> I've been building Nagios3 betas1-3 without any issues, but with this
>>>> latest release I ran into a compile problem. Using Sun Studio on
>>>> Solaris 9 I'm seeing this:
>>>> cc -I/usr/local/include -DHAVE_CONFIG_H -I/usr/local/include/glib-2.0
>>>> -I/usr/local/lib/glib-2.0/include -DNSCGI -L/usr/local/lib
>>>> -R/usr/local/lib -L/usr/sfw/lib -R/usr/sfw/lib -L/usr/local/lib -o
>>>> config.cgi config.c getcgi.o cgiutils.o cgiauth.o macros-cgi.o
>>>> ../common/snprintf.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o
>>>> xstatusdata-cgi.o comments-cgi.o downtime-cgi.o -lrt -L/usr/local/lib
>>>> -lglib-2.0 -liconv "cmd.c", line 2296: warning: no explicit type given
>>>> for parameter: cmd
>>>> "config.c", line 135: warning: implicit function declaration: init_macros
>>>> "config.c", line 473: warning: implicit function declaration:
>>>> grab_host_macros
>>>> Undefined first referenced
>>>> symbol in file
>>>> use_large_installation_tweaks macros-cgi.o
>>>> ld: fatal: Symbol referencing errors. No output written to cmd.cgi
>>>> gmake[1]: *** [cmd.cgi] Error 1
>>>> gmake[1]: *** Waiting for unfinished jobs....
>>>> "config.c", line 1203: warning: implicit function declaration:
>>>> grab_service_macros
>>>> symbol in file
>>>> ld: fatal: Symbol referencing errors. No output written to config.cgi
>>>> gmake[1]: *** [config.cgi] Error 1
>>>> symbol in file
>>>> ld: fatal: Symbol referencing errors. No output written to avail.cgi
>>>> gmake[1]: *** [avail.cgi] Error 1
>>>> use_large_installation_tweaks never gave me any troubles before, was
>>>> this something that was recently added? I'm guessing it's defined
>>>> somewhere that's not being linked to, but a quick grep shows me its
>>>> just in check.c, config.c, events.c, nagios.c, macros.c, and utils.c
>>>> rather than any header references.
>>>> Any help would be appreciated.
>>>> Thanks,
>>>> -Dave
David Halik
Systems Programmer
OSS/NBCS - OIT Rutgers
[email protected]
