------=_NextPart_000_0075_01C6503C.83B62510
Content-Type: text/plain;
charset="us-ascii"
Hi Ethan,
> i just tried to compile the cvs version of nrpe on a solaris
> 2.6 machine.
i had a closer look at it, so i will answer myself...
The problem is the IPv6 support. What was a good intention prevents a
successful compilation of the is_an_allowed_host function. INET6_ADDRSTRLEN
and inet_ntop are not available in elder operating systems. (I do not say
deprecated, because you still find Solaris2.6 machines everywhere).
The IPv6-awareness also is a bit ahead, as throughout of nrpe.c inet_ntoa is
used.
So i made a patch which makes the DNS lookup in is_an_allowed_host IPv4-only
again.
Greetings from Munich,
Gerhard
Content-Type: application/octet-stream;
name="nrpe-2.5pre-allowedhosts.ipv4.patch"
filename="nrpe-2.5pre-allowedhosts.ipv4.patch"
diff -Naur nrpe-2.5/src/nrpe.c nrpe-2.5.ipv4/src/nrpe.c=0A=
--- nrpe-2.5/src/nrpe.c 2006-03-25 15:23:32.000000000 +0100=0A=
+++ nrpe-2.5.ipv4/src/nrpe.c 2006-03-25 18:26:20.310220083 +0100=0A=
@@ -882,7 +882,8 @@=0A=
int result=3D0;=0A=
struct hostent *myhost;=0A=
char **pptr=3DNULL;=0A=
- char resolved_addr[INET6_ADDRSTRLEN]=3D"";=0A=
+ char *save_connecting_host;=0A=
+ struct in_addr addr;=0A=
=0A=
/* make sure we have something */=0A=
if(connecting_host=3D=3DNULL)=0A=
@@ -909,6 +910,7 @@=0A=
if((temp_buffer=3Dstrdup(allowed_hosts))=3D=3DNULL)=0A=
return 0;=0A=
=0A=
+ save_connecting_host =3D strdup(connecting_host);=0A=
for(temp_ptr=3Dstrtok(temp_buffer,",");temp_ptr!=3DNULL;temp_ptr=3Dstrtok=
(NULL,",")){=0A=
=0A=
myhost=3Dgethostbyname(temp_ptr);=0A=
@@ -916,9 +918,8 @@=0A=
=0A=
/* check all addresses for the host... */=0A=
for(pptr=3Dmyhost->h_addr_list;*pptr!=3DNULL;pptr++){=0A=
-=0A=
inet_ntop(myhost->h_addrtype,*pptr,resolved_addr,sizeof(resolved_addr));=0A=
- if(!strcmp(resolved_addr,connecting_host)){=0A=
+ memcpy(&addr, *pptr, sizeof(addr));=0A=
+ if(!strcmp(save_connecting_host, inet_ntoa(addr))){=0A=
result=3D1;=0A=
break;=0A=
}=0A=
@@ -928,6 +929,8 @@=0A=
if(result=3D=3D1)=0A=
break;=0A=
}=0A=
+ strcpy(connecting_host, save_connecting_host);=0A=
+ free(save_connecting_host);=0A=
}=0A=
=0A=
free(temp_buffer);=0A=
------=_NextPart_000_0075_01C6503C.83B62510--
