Re: [Nagios-devel] netutils use of socket descriptor
Thomas Guyot-Sionnest wrote:
> Good catch, though it looks like it will have no effect whatsoever.
> According to socket(2):
> On success, a file descriptor for the new socket is returned. On
> error, -1 is returned, and errno is set appropriately.
> In other words if sd is not condition will always succeed (just like when testing the pointer) and
> there is no need to walk further the r list.
ah yes, I see that now.
> If you want to connect with a given per-address or global timeout, then
> you'll have to include most of the rest of the function in the while(r)
> loop... unfortunately that will give you a per-ip timeout which is
> likely not desired.
> A better way of doing this is to send a connect for the next ip in list
> every n miliseconds (where n is a small fraction of the timeout, you
> could for example take half of the timeout and divide it by the number
> of IP), use the first connected socket and clean up the rest.
I'm not trying to solve any immediate problem, I was just having a look
and came across that, so I'm not inclined to change its current
behavior. thanks for the reply.
