Re: [Nagios-devel] Advanced permissions/user properties
As there is still no PHP replacement interface for Nagios, I have
decided to update my advanced permissions patch that I posted last year.
I am currently using it in production with Nagios 2.8.
I have updated the 2.x patch to support Nagios 2.8 and 2.9. I will be
updating the 3.x patch to support 3.0b4 soon.
The current version of the patch can be found at
http://www.fragit.net/nagios.html
I would appreciate any comments or suggestions.
Alex
Alex Burger wrote:
> On the Nagios-Users list there is a discussion on the same subject about
> adding advanced permissions to Nagios for hosts and services. Users
> (including myself) were looking for a way to grant users the ability to
> view hosts, but not submit commands and to allow for more complex
> permissions.
> It made the most sense to model the permission system with how file
> system permissions are handled. With file system permissions, we would
> assign a group to a folder, and then pick what rights the group would
> have. It made sense to do the same thing with Nagios in the
> contact_groups/contact option for hosts and services:
> *Examples:*
> define host{
> host_name localhost
> contact_groups netops:rwxn, helpdesk:r
> contact alex:rwxn (Nagios 3)
> For backwards compatibility, if no permissions are set, the defaults
> would be rwxn (as defined in cgi.cfg and nagios.cfg) so the following
> would be the same:
> define host{
> host_name localhost
> contact_groups netops, helpdesk:r
> contact alex (Nagios 3)
> *Permissions:*
> r: View in web interface
> x: Submit commands for this host/service in web interface
> w: Not really needed yet. Maybe some of the other programs that allow
> you to modify the configuration files could use w to allow a user to
> modify the host / service.
> n: Notify if contact has a pager or email defined
> The addition of these permissions allow for senarios such as:
> -you want users to be able to view all or some hosts and services, but
> not submit commands
> also be able to submit commands for a select few
> only get notifications for only a select few
> If permissions are not set on the contact_groups or contact line, then
> the defaults will be used. If there is no default_permissions option in
> cgi.cfg and nagios.cfg, then it will default to full permissions (the
> same checks that Nagios currently performs).
> Here is a description of the option for cgi.cfg and nagios.cfg:
> # DEFAULT HOST/SERVICE PERMISSIONS
> # This option contains a list of default permissions for hosts and
> # services that will be used when permissions are not explicitly
> # set on a host or service. When not defined, the default is all
> # permissions (rwxn). Note: This option must be set the same in
> # both cgi.cfg and nagios.cfg.
> #default_permissions=rwxn
> As you can see, the option needs to be in both config files although I
> would prefer to have it only in nagios.cfg. It is needed in nagios.cfg
> for base/notifications.c which has nothing to do with the cgi. If
> someone knows how to combine the two, please let me know.
> I also changed how services are displayed. If you are not a contact for
> a service (you do not have the 'r' permission), then the service will
> not be displayed. I prefer to have it this way so I can prevent some
> admins from seeing services such as a the service I use to receive SNMP
> traps. The problem with this right now is that even though the user
> only sees the services they has permissions for, as long as the user has
> rx permissions to the host, the user can do a 'Enable notifications for
> all services on this host' which will do ALL services.
> If this patch is accepted, then we will have to add permission checks to
> the commands that proce
...[email truncated]...
