HI I am not able to use the wizard to check https servers I get Connection Refused can you please advise also can you recomend a product to find OID's in snmp
Regards, Dave
HTTPS servers
Re: HTTPS servers
I can reproduce this. I'll take a look at it on Monday.
Can you recomend a product to find OID's in snmp:
I use the command line tool(s) snmptranslate and vi/less.
Re: HTTPS servers
This was discussed. The process is to select certificate checking and then you also get HTTPS.
