[Nagios-devel] compile problems with 3.0.6 under Solaris
with version 3.0.6 i get the following error on a solaris system again
(which was fixed with version 3.0.3):
/opt/gcc/bin/gcc -O3 -pipe -mcpu=niagara -mtune=niagara
-I/usr/local/include -DHAVE_CONFIG_H -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -DNSCORE -o nagios nagios.c broker.o
nebmods.o checks.o config.o commands.o events.o flapping.o logging.o
macros-base.o notifications.o sehandlers.o skiplist.o utils.o
retention-base.o xretention-base.o comments-base.o xcomments-base.o
objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o
perfdata-base.o xperfdata-base.o downtime-base.o xdowntime-base.o
../common/snprintf.o -L/usr/local/lib -lm -lpthread -ldl -lrt
-lglib-2.0
gcc: ../common/snprintf.o: No such file or directory
*** Error code 1
make: Fatal error: Command failed for target `nagios'
Current working directory /root/nagios/nagios-3.0.6/base
*** Error code 1
make: Fatal error: Command failed for target `all'
workaround: cp ./base/snprintf.o ./common && make all
could anybody have a look on this?
if you need more infos let me know.
regards,
michael
