nope.. someone else posted the code, and I just applied it to my tree.
On Wed, 9 Feb 2005 13:42:37 +1100, Stanley Hopcroft
wrote:
> Dear Sir,
> I am writing to thank you for your letter and say,
> On Wed, Feb 09, 2005 at 12:30:15PM +1100, Ian Holsman wrote:
> > If startup is an issue then just use a hash table on the xod
> > structures. I changed the code a bit so that it just inserted the host
> > records as soon as it saw them into the main list, and
> > xod_find_service checked that.
> > I also modified the 1.x code so it uses glib's hash functions and
> > added a list of services for each host on the host record structure.
> Ach, so it was you that did that ! The glib hash patch worked very
> nicely on a 1.2 base with ~300 hosts. Performance was comparable to
> 2.0b1.
> Thank you very much.
> Yours sincerely.
> Stanley Hopcroft
> IP Australia
> Ph: (02) 6283 3189 Fax: (02) 6281 1353
> PO Box 200 Woden ACT 2606
> http://www.ipaustralia.gov.au
> This message contains privileged and confidential information only
> for use by the intended recipient. If you are not the intended
> recipient of this message, you must not disseminate, copy or use
> it in any manner. If you have received this message in error,
> please advise the sender by reply e-mail. Please ensure all
> e-mail attachments are scanned for viruses prior to opening or
> using.
