Re: [Nagios-devel] avail.cgi bug report
------=_Part_12260_264487.1188828594610
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Thanks for quick reply!
Seems like Custom Period doesn't work here at all :-(
I just tried on some other services any period in past that's not including
yesterday's date and it fails.
On 03/09/07, Andreas Ericsson wrote:
> > Hello,
> > seems like there's a bug in avail.c. I'm trying to get availability
> report
> > with 'LastMonth' as time period, but it fails, I get all undetermined or
> > UP/ok if I choose assume state.
> > All other time periods are working. Custom time period also doesn't
> work,
> > but it works if I set to day before today. 2 days before today also
> failes.
> > I'm guessing this works only when today's (or yesterday) date is
> included.
> > I'm using Nagios 2.6, I haven't seen a patch in CVS for this bug (nor
> bug
> > report).
> > What do you recommend?
> Hunting down the bug and submitting a patch ;-)
> We've seen this problem too, although only under "complex circumstances",
> such
> as multiple scheduled downtimes mixed with host-up, host-down and outages
> alerts. I have no solution at the moment, and debugging avail.c is far
> from a
> simple matter since determining that the bug is solved once a probable fix
> is
> in place is difficult and enormously timeconsuming.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Nagios-devel mailing list
> [email protected]
best wishes,
Franjo Stipanovic
Content-Type: text/html; charset=ISO-8859-1
Thanks for quick reply!Seems like Custom Period doesn't work here at all :-(I just tried on some other services any period in past that's not including yesterday's date and it fails.
On 03/09/07, Andreas Ericsson <[email protected]> wrote:
> Hello,> seems like there's a bug in avail.c. I'm trying to get availability report> with 'LastMonth' as time period, but it fails, I get all undetermined or> UP/ok if I choose assume state.
> All other time periods are working. Custom time period also doesn't work,> but it works if I set to day before today. 2 days before today also failes.> I'm guessing this works only when today's (or yesterday) date is included.
>> I'm using Nagios 2.6, I haven't seen a patch in CVS for this bug (nor bug> report).>> What do you recommend?>Hunting down the bug and submitting a patch ;-)
We've seen this problem too, although only under "complex circumstances", suchas multiple scheduled downtimes mixed with host-up, host-down and outagesalerts. I have no solution at the moment, and debugging
avail.c is far from asimple matter since determining that the bug is solved once a probable fix isin place is difficult and enormously timeconsuming.--Andreas Ericsson
[email protected] AB   &nbsp
...[email truncated]...
