Re: [Nagios-devel] colourblindness issue
Another approach would be for the user to apply some kind of
userContent.css so that
the confusion colours (red/green I'm guessing) get mapped to
blue/yellow or something.
also .. things like greasemonkey (http://greasemonkey.mozdev.org/)=20
could help them as well.
On 6/16/05, Andreas Ericsson wrote:
> Arno Lehmann wrote:
> > Hello,
> > I just stumbled over a mail in the userlist, asking how to change
> > colours... and there I had the - probably - right idea.
> > Modify the stylesheet Nagios uses. Perhaps adding another one which
> > could be seklected by the user is the best solution, but that would
> > (probably, I don't know the source) require a patch to the cgis.
>=20
> This other one can already be included (although not on a per user
> basis). I hacked in support for adding a "common.css" to the cgi's,
> hoping that some clever GUI folks would start hacking up skins. Using
> the login-name to determine the css-name shouldn't be all too difficult
> though.
>=20
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Lead Developer
>=20
>=20
> SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
> from IBM. Find simple to follow Roadmaps, straightforward articles,
> informative Webcasts and more! Get everything you need to get up to
> speed, fast. http://ads.osdn.com/?ad_id=3D7477&alloc ... op=3Dclic=
k
> Nagios-devel mailing list
> [email protected]
>=20
--=20
[email protected] -- 03-9877-0909
If everything seems under control, you're not going fast enough. -
Mario Andretti
