gcc -g -O2 -I/opt/imagelib/include -DHAVE_CONFIG_H -DNSCORE -o nagios nagios.c broker.o nebmods.o checks.o config.o commands.o events.o flapping.o logging.o notifications.o sehandlers.o utils.o retention-base.o xretention-base.o comments-base.o xcomments-base.o objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o perfdata-base.o xperfdata-base.o downtime-base.o xdowntime-base.o -L/opt/imagelib/lib -lm -lnsl -lsocket -lpthread -ldl
Undefined first referenced
symbol in file
nanosleep events.o
ld: fatal: Symbol referencing errors. No output written to nagios
collect2: ld returned 1 exit status
To get nanosleep on Solaris, so you have to link with -lrt.
(it's also in -lposix4, but will be removed in future versions)
This should be tested for by autoconf.
I was prepared to provide an autoconf patch, but configure.ac was not
included in the CVS sources. However, something like this is probably all
that is needed.
AC_SEARCH_LIBS(nanosleep, [rt], [posix4], [], [
echo "nanosleep() required for timing operations."
exit 1
Joe Rhett Chief Geek
[email protected] Isite Services, Inc.
