------=_NextPart_000_0098_01C815A1.587268B0
Content-Type: text/plain; format=flowed; charset="iso-8859-1";
reply-type=response
>> Valgrind should be able to give a few hints. If you've got time to run
>> Nagios
>> under it on your system, it would most likely be very valuable.
> Not sure how to do this but I've got the time and willingness to learn.
> Just point me at some documentation and I'll plug away at it. I've done a
> little googling and have run the program with this for tonight:
> valgrind --leak-check=yes --time-stamp=yes --log-file=/tmp/trace/nagios-valgrind
> nagios /etc/nagios/nagios.cfg
> I'll make the results available tomorrow. If you would like other options
> please let me know which ones.
Well that didn't take nearly as long to fail as previous attempts. I've
attached both the nagios.log and the valgrind save. Let me know if there is
anything else you need.
-Shad
Content-Type: application/octet-stream;
name="nagios.log.gz"
filename="nagios.log.gz"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name="nagios-valgrind.gz"
filename="nagios-valgrind.gz"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...[email truncated]...
