Re: [Nagios-devel] small issue with lock_author_names
On Sat, Dec 22, 2007 at 06:48:32PM -0500, Thomas Guyot-Sionnest wrote:
> In our systems we used the attached patch (written by me some time ago)
> to remove domain part and make the username lowercase (Windows AD
> doesn't care about the case while the cgi do, so this avoid us problems).
We have about 20 Active Directory domains with one top level AD domain
(root domain), so I need to distinguish user muellert@ABC from user
muellert@DEF.
> The patch is against mod_auth_kerb-5.3 but since it's pretty simple it
> might as well apply fine on future versions.
I prefer the full qualified name user@REALM.
> We have some problems with that and never took time to investigate. What
> version of the various software did you use? Any particular document you
> followed? You're authenticating against a Windows Server 2003 based AD?
I'm using authentication against an Active Directory based on Windows
Server 2003 R2. Some documents I found in the Microsoft technet base
(especially for creating a working service ticket for apache)
and the original documentation of mod_auth_kerb. My collegues
had some trouble with IE 6 and older mod_auth_kerb version
(first authentication works, but after some time, the
reauthentication fails and the browser asks the user to enter a
password), I never had such problems with Firefox. With
mod_auth_kerb 5.3 on apache 2.2 all work's fine.
Applications: mainly web based applications on apache2: nagios, webdav,
some self developed applications. The next SSO project is Typo3 (eu_ldap
for frontend authentication with some small modifications).
The really critical point in all kerberos environments is correct resolving
host names (correctly configured DNS).
May be we can discuss SSO per personal mail, because it is a little of
topic here ;-)
Wolfgang
* http://www.swobspace.de
Original poster: [email protected] (Wolfgang Barth
