On 10/06/2011 01:07 PM, Dorian Guillois wrote:
> Hi everybody,
> Attached patches fix some bugs on functions delete_all_host_comment,
> unschedule_downtime and
> delete_downtime_by_hostname_service_description_start_time_comment. In
> this 3 functions a pointer on a deleted object is used.
Good catch.
There's a bug in your patches though. In all cases you point next_item to
this_item->next, but then iterate it using next_item->next, meaning you'll
skip every other item.
If you resend corrected patches I'll apply them. Thanks
OP5 AB www.op5.se
on peace.
