Re: [Nagios-devel] alright, this is getting downright retarded...
> > Well, automake-1.6 and autoconf-2.58 pukes all over these files as well.
> > Please someone tell me you're halfway through a commit?
> Hmmm. I'm running automake 1.78 and autoconf 2.57 (on Fedora Core 1), no
> problems here.
I just upgraded to the latest, I was about one version before yours, now
I'm at 1.79 and 2.58 just like you mentioned in your followup message.
> > I'm more than willing to spend time and effort hacking away on this, but
> > the development environment needs to be even halfway capable of providing a
> > build.
> I guess the first thing that would help is to find out why the gnu tool
> chain is failing for you. Can you be more specific than "pukes"
cyclops 490% aclocal
aclocal: configure.in: 1406: macro `AM_GNU_GETTEXT_VERSION' not found in library
aclocal: configure.in: 1407: macro `AM_GNU_GETTEXT' not found in library
cyclops 490% autoconf
configure.in:6: error: possibly undefined macro: AM_INIT_AUTOMAKE
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.in:1406: error: possibly undefined macro: AM_GNU_GETTEXT_VERSION
configure.in:1407: error: possibly undefined macro: AM_GNU_GETTEXT
cyclops 491% autoheader
cyclops 492% automake
configure.in: no proper invocation of AM_INIT_AUTOMAKE was found.
configure.in: You should verify that configure.in invokes AM_INIT_AUTOMAKE,
configure.in: that aclocal.m4 is present in the top-level directory,
configure.in: and that aclocal.m4 was recently regenerated (using aclocal).
configure.in: required file `./install-sh' not found
configure.in: required file `./mkinstalldirs' not found
configure.in: required file `./missing' not found
configure.in:8: required file `./config.guess' not found
configure.in:8: required file `./config.sub' not found
Makefile.am: required file `./INSTALL' not found
lib/Makefile.am: required file `./depcomp' not found
/opt/gnu/share/automake-1.7/am/depend2.am: am__fastdepCC does not appear in AM_CONDITIONAL
/opt/gnu/share/automake-1.7/am/depend2.am: AMDEP does not appear in AM_CONDITIONAL
Just FYI, we use autoconf for our internal code and I use it daily for
various other projects we're tracking via CVS. There are no system problems
with autoconf that I'm aware of, and we do use it daily.
Joe Rhett Chief Geek
[email protected] Isite Services, Inc.
