Re: [Nagios-devel] BUG: Passive host check results are always in
[email protected] wrote:
> Hi,
> We have a distributed Nagios set-up with three (slave) check engines
> performing active checks and sending their results to a master server
> which collects all results and sends out alarms if need be.
> Our department had a lot of complaints regarding remote hosts connected
> over a WAN link that give out a lot of false positives.
> Because WAN links are more prone to packet loss than LAN links, we've
> set the number of host retries to 10, figuring that this would avoid any
> false alerts about hosts being down while in fact it is just a temporary
> glitch in the line.
> This setup did not work however. Further investigation about the cause
> revealed what I believe to be a bug.
> */While receiving host check results in PASSIVE mode, the number of
> retries is not taken into account and a negative response will
> immediately results in a HARD state, which in turn sends out alerts./*
[snip]
> Note that PASSIVE services checks work as expected, it's only host
> checks that exhibit this behaviour.
> Would it be possible to post a patch for this bug or could a fix be
> incoporated in a next release?
> Best Regards,
> Jan David
This is a feature, rather than a bug, but the behavior is undesireable.
The host check logic has changed in the 3.0 development code and
passive checks no longer result in HARD-only states.
Ethan Galstad,
Nagios Developer
Email: [email protected]
