On Fri, 28 Feb 2003, Frank Sweetser wrote:
> First, the quickie background. We're in the process of setting up nagios to
> monitor our network - not the hosts on it, but our collection of routers and
> switches. This means that a few of the host based assumptions that nagios
> makes kinda break, but the biggest one right now is the fact that a single host
> can have multiple IPs associated with it.
This has changed - see Ethan's post from last week - comma speparated
multiple IP addesses can be inserted for a HOSTADDRESS. check_ping in the
post 1.3 CVS was just modified to accept multiple addresses.
> Now the easiest way I can think of to monitor multiple IPs on a single host
> while still keeping a single host definition is to define a service for each IP
> beyond the primary management one. The problem this brings in is dependancies.
> Any nodes downstream aren't dependant not only upon the router as a whole being
> operational, but also its particular interface.
> So what I would love to see is the ability to define the parent of a given host
> to be not just another host, but a list of services on another host.
> For example, take a router with two interfaces, ifA is closest to the nagios
> box, and ifB is a seperate interface defined as a service. So it would look
> something like
> nagios ------- ifA | router | ifB ------- other host
> So at first glance, router should be the parent of other host. However, if
> ifB goes down but ifA stays up, then other host will be incorrectly flagged
> as down rather than unreachable. If nagios could be told that the parent is
> not just router, but service ifB on router, with a syntax like
> parent router!ifB
> then nagios could do The Right Thing.
> I've identified at least some of the code points that would have to be
> modified (in the template config stuff only), and am willing to take a crack
> at it if no one else will.
> So would such a feature be considered for inclusion?
-sg
