[Nagios-devel] Mass define servicedependency for NRPE services
The subject has already been discussed on this mailinglist but all
solutions I found did not satisfied my needs.
I would like to be able to create a servicedependency for each service
hosted on a host with NRPE installed against the NRPE service itself.
Unfortunately, servicedependency does not allow you to massively define
service dependencies against a single service hosted on the same host as
the service.
Basically, I don't want to have to define a servicedependency for each
host that has NRPE installed on it and even less for each NRPE based
service.
I would like to be able to use this definition:
define servicedependency {
; NRPE service for each hosts referred by services in nrpe-services
; The NRPE service has previously been mass-defined on all hosts
; with NRPE installed using a host template
service_description NRPE
; Every NRPE based services
; Each NRPE based service is added to nrpe-services
; using a service template
dependent_servicegroup_name nrpe-services
execution_failure_criteria n
notification_failure_criteria c,u
How hard would it be to implement this feature? Is it even possible?
Would it be the right "way" to do it? Any idea? Thanks!
Note: I think a similar idea has already been proposed here:
http://ideas.nagios.org/akira/dtd/2078-3955
Mathieu
