Re: [Nagios-devel] NDOUtils + PostgreSQL?
I submitted PgSQL code + nagios 2.x patches a few months ago. I don't know =
if=20
Ethan read it or not.=20
Ethan told me that it should be more interesting to wait for the final db=20
scheme version.
Le jeudi 08 novembre 2007, Andreas Ericsson a =E9crit=A0:
> Antonio Grassi wrote:
> > Hi list. Maybe this message should have been sent to nagiosplug-devel,
> > sorry if that is the case.
> > I've been trying NDOUtils, and got it working with MySQL. I've also seen
> > that there are plans to add support for PostgreSQL storage, and browsing
> > the code I see there is already some work in that direction. I've also
> > seen there are a couple of messages in nagios-devel and nagiosplug-devel
> > about versions with certain support for PostgreSQL, using 1.4b2 and 1.4=
b3
> > versions of NDOUtils.
> > I tried Nagios 3.0b5 and NDOUtils 1.4b6. The scripts for the creation of
> > the database schema are only for MySQL. I converted the script to
> > PostgreSQL format, and modified ndo2db.c to enable PostgreSQL. But when=
I
> > turn everything up, I see that there are also hardcoded queries with
> > MySQL SQL format.
> I thought most queries were in ANSI SQL. In what way are the queries
> incompatible with PostgreSQL (or any other sql-engine, for that matter)?
I should check the queries again.
> > - is there a brach or something I'm missing, with a better grade of
> > support for PostgreSQL?
> Shouldn't think so. I haven't found one anyways.
> > - is there somebody working in PostgreSQL support for NDOUtils (if yes,
> > who)?
I am waiting for the final db scheme version to work on it.
> Not that I know of. Did google turn up blank?
Mathieu
