Ton Voon wrote:
Hallo Ton,
> Which bit do you mean here?
> I would have thought it should always be mysql.h, rather than mysql/
> mysql.h because mysql_config --include should point to the directory
> holding mysql.h. Could it be that mysql_config is set incorrectly in
> the Centos distribution?
you are right. You modification works also on Centos. The gcc command
contains -I/usr/include/mysql. I can compile Ndoutils without problems.
Herbert
