On 11 Aug 2004 at 6:43, Ian Holsman wrote:
> do a search for RLIMIT_CORE in utils.c and delete the setrlimit call.
> then in the shell before you call nagios do ulimit -c unlimited
> this should let nagios actually dump core and then you can see what is
> causing it.
> --Ian
> hey Ethan.. what is the logic behind disabling cores in the code like
> this instead of using ulimit?
[snip]
I think Karl actually submitted the initial patch to do this. I
believe the reasoning behind it is that daemons are not supposed to
dump core when they bail. Its not a big deal, as most bugs can be
caught when you run Nagios as a foreground process - this allows a
core file to be created.
Ethan Galstad,
Nagios Developer
Email: [email protected]
