Re: [Nagios-devel] bug using check_interval
Hash: SHA1
On 19/01/09 12:53 PM, Martin, Matthew wrote:
> When I have “check_interval” interval set in a host definition it works
> correctly, but when I do not have it set the host gets a “check_command”
> scheduled every five minutes, instead of no checks being scheduled as it
> should be.
> I am running Nagios Version 3.0.6 on Solaris 10 update 6, on i86pc hardware.
In Nagios 3.x host checks are expected to be scheduled. They aren't run
serially anymore and together with result caching this is the biggest
performance enhancement between Nagios 2 and 3.
So you should leave them one. The only gotcha is that you'll likely want
to change the interval_lenght if you changed the interval_length.
BTW, the default should be something like 300/interval_length rather
than "5" - in my case I had interval_lentgh set to 1 and I quickly
noticed Nagios was scheduling host checks every 5 seconds!!!
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJdOiv6dZ+Kt5BchYRAmyVAJsFx+IloDIqyD7eU57Ue2JNamvqvwCePmWW
aHGRCI0PiauPWBW2W/ICQqQ=
=bWbj
-----END PGP SIGNATURE-----
