Hi Marco,
sorry for late answer. I have to wait for today to test this on a nagios2.x.
Seems that you are right about the TAC.
I've made a Screenshot for others on this list on
http://process-zero.de/nagiosscr/tac-pa ... oblems.png
Since that the information that active checks are disabled is mentionend
under "Monitoring Features" I would suggest to not differ between
enabled / disabled active checks under "Services".
@List: Any thoughts about this?
Marco Supino schrieb:
> Hi,
> If I disable active checks for services, if a service has a problem, it
will show up in the TAC as "Disabled" instead of "problem",
> I want errors to show up as problems, colored in red, and playing the
WAV associated with the problem's level , If its disabled, its not
"highlighted",
> I followed this http://nagios.org/faqs/viewfaq.php?faq_id=271 in order
to achive the status of "passive - and not disabled - and freshness
checking",
This FAQ entry is AFAIK obsolete since there have been changes to
freshness between nagios 2.? and 2.? (sorry, can't remember the
subreleases).
> The way I wanted it to work is that active checks are regularly
scheduled, but if the results are below the freshness threshold, the
service check should not run, and be rescheduled, it does not work in
this way.
> Marco.
Regards
Hendrik
