Re: [Nagios-devel] WG: NDO 1.4b7 - nagios_hosts Field Aliases in
------_=_NextPart_001_01CBFA8D.C10EF24A
Content-Type: text/plain;
charset="iso-8859-1"
Here some addtional Informations attached
Environment: nagios 3.2.3 / ndo 1.4b7
=20
regards
=20
i.A. Christian Mies
Senior Consultant
Tel: +49 (661) 103-874 (-333) =20
Fax: +49 (661) 103-17874 (-334)
mailto:[email protected]
=20
it-novum GmbH . Edelzeller Strasse 44 . 36043 Fulda . =
http://www.it-novum.com
Handelsregister Amtsgericht Fulda, HRB 1934 . Gesch=E4ftsf=FChrer: =
Michael Kienle . Sitz der Gesellschaft: Fulda
Der Inhalt dieser E-Mail ist vertraulich. Wenn Sie nicht der eigentliche =
Empfaenger sein sollten, informieren Sie bitte sofort den Absender oder =
vernichten umgehend diese Mail. Jegliche unerlaubte Vervielfaeltigung =
oder Weiterleitung dieser Mail ist strengstens verboten.
This e-mail may contain confidential and/or priviledged information. If =
you are not the intended recepient (or have received this e-mail in =
error) please notify the sender immediately and destroy this e-mail. Any =
unauthorised copying, disclosure or distribution of material in this =
e-mail is strictly forbidden.
________________________________
Von: Mies, Christian [mailto:[email protected]]
Gesendet: Do 14.04.2011 11:59
An: Nagios Developers List
Betreff: AW: [Nagios-devel] WG: NDO 1.4b7 - nagios_hosts Field Aliases =
in Configtype 1
Hi Michael,
thank you for the fast answer. After looking at documentation I set up
=20
retail_nonstatus_informatoin=3D0 in my Host Template.=20
I've looked at the retension.dat, but there still standing the name =
before changing Alias Value.
=20
Do you know the changes between Nagios 3.2.1 and Nagios 3.2.3 in the =
retension Part? With nagios 3.2.1 everything working fine for moving =
files to the Database...
=20
Regards
Christian
Von: Michael Friedrich [mailto:[email protected]]
Gesendet: Do 14.04.2011 11:10
An: [email protected]
Betreff: Re: [Nagios-devel] WG: NDO 1.4b7 - nagios_hosts Field Aliases =
in Configtype 1
Mies, Christian wrote:
> i.A. Christian Mies
> Senior Consultant
http://www.it-novum.com =20
> Der Inhalt dieser E-Mail ist vertraulich. Wenn Sie nicht der =
eigentliche Empfaenger sein sollten, informieren Sie bitte sofort den =
Absender oder vernichten umgehend diese Mail. Jegliche unerlaubte =
Vervielfaeltigung oder Weiterleitung dieser Mail ist strengstens =
verboten.
> This e-mail may contain confidential and/or priviledged information. =
If you are not the intended recepient (or have received this e-mail in =
> Gesendet: Do 14.04.2011 10:27
> Betreff: NDO 1.4b7 - nagios_hosts Field Aliases in Configtype 1
> Hi Nagios Devel List,
> I hope I'm right at that list. I cannot find a seperate List for the =
NDOUtils
> Historically we need to use NDO 1.4b7 - please don't ask why I'm using =
it.
> Since the Nagios Update from 3.2.1 to 3.2.3 the Host Alias in table =
nagios_hosts Configtype 1 will not updated if I change the Alias in the =
Configuration. I've looked at the broker.c and broker.h Code but the =
only difference I found, was that a variable in 3.2.3 is int instead of =
void.
> Has anybody of you an idea how to fix the issue, that the =
nagios_hosts.alias on configtype 1 will be updated on Nagios restart?
look for retention.dat and the host alias savings/restor
...[email truncated]...
