[Nagios-devel] Nagios-1.1 config file parsing bug
Hi all!
I noticed a problem with the config file parsing code in Nagios 1.1, when
using the new (template-based) format:
Blanks in various object names (hosts, contact-groups, ...) are not handled
correctly when they appear in a list.
Example: with a service definition like this:
use my_template
host_name host a,host b,host c
service_description Connectivity Check
check_command check_ping
Nagios will complain that host "host" is undefined, instead of looking up
"host a".
Can anyone please make a patch available? Thanks!
Regards,
Florian Kirchmeir
