Mikael Fridh wrote:
> On Wed, Sep 17, 2008 at 7:46 PM, Andreas Ericsson wrote:
>> Benjamin Krein wrote:
>>> Is there a reason log entries aren't split up into multiple fields in
>>> the NDO DB? It seems kind of silly to put the entire log line in a
>>> single field when there are very clear delimiters in the line.
> These are a few excerpts of the logentries;
> Auto-save of retention data completed successfully.
Junk.
> LOG ROTATION: DAILY
Implementation detail junk.
> CURRENT HOST STATE: bernicla2;UP;HARD;1;PING OK - Packet loss = 0%,
> RTA = 0.50 ms
Useful, but superfluous (especially with LOG_ROTATION: Daily).
> ndomod: Successfully reconnected to data sink! 0 items lost, 88
> queued items to flush.
NEB junk. Will go to separate logfile in a not too far off future.
> CURRENT SERVICE STATE: rt-130-238-128-160-27;PING;OK;HARD;1;PING OK -
> Packet loss = 0%, RTA = 2.77 ms
See comment for CURRENT HOST STATE entry.
> There are only clear delimiters for some types of entries, not all.
> And if you do separate the types into different tables it will stop
> being a Log... A log is where you go to check historically what
> happened during a certain period of time. If you split it up in
> separate tables it will be more complex to get an excerpt on just that
> - all events during a certain period.
>> I imagine the current structure was designed to facilitate displaying
>> the entire log though. Your guess is as good as mine, as it was a long
>> time ago I took a look at the ndoutils code.
> It's a log on disk, thus it's a log in the database. Atleast that's my
> take on it.
> I would use MyISAM MERGE tables or PARTITIONS for this if you want to
> keep an "online" archive of the logs.
> With the MERGE trick you can compress old tables and rejoin them in
> the merge periodically if you'd like.
Or one can just print the logfiles from disk. They're already partitioned
into rotated logfiles so it's not that much of a chore.
>>> I'm contemplating writing my own parser for the archived logs, but I'm
>>> tempted to modify the NDO code to make use of multiple fields.
> You could modify the ndo code to recognize more event types. There are
> a few logentry_type IDs that are duplicate it seems.
> The event history of objects (services and hosts) is already in
> nagios_statehistory, so what else is there in the log that you could
> gain so much from parsing out into separate tables/fields?
Notifications. Program start and stop. Downtime start and stop.
Adding a *raw* log to the database just duplicates the log that's
already saved on disk, so it buys us absolutely nothing while not
taking advantage of the indexing that a database can offer. And
even if the logfiles would ever go away (not likely), it's totally
trivial to concatenate logentries from several tables when one
wants to view them.
OP5 AB www.op5.se
