--0-94265849-1188508603=:32787
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
thanks patrick for this this looks very promising i will try this and let me know the status
Patrick Proy wrote: Hi,
You can use regular expressions to select a lot of ports at once (ex :
GigabitEthernet 5/* for all the ports of card 5) with the check_snmp_int
plugin.
Use the C version if you have a big number of interface to use the index
caching capabilities of the plugin.
Info & downloads : http://nagios.manubulon.com
Regards,
Patrick
________________________________
De : [email protected]
[mailto:[email protected]] De la part de rajesh
Envoyé : jeudi 30 août 2007 15:33
À : [email protected]
Objet : [Nagios-devel] cisco switches and routers physical port status
withnagios
Hi Guys,
I need to monitor cisco switches and routers physical port status.Can i use
check_ifoperstatus plugin or not.One more question my switch port is having
25 or 50 ports how do i check the status.This plugin check all interfaces by
default or i have to menction each interface.
Thanks for your help
Best Regards
Once upon a time there was 1 GB storage in your inbox. Click here for happy
ending.
l/yahoomail/tools/tools-08.html/>
This SF.net email is sponsored by: Splunk Inc.
Still grepping through log files to find problems? Stop.
Now Search log events and configuration files using AJAX and a browser.
Download your FREE copy of Splunk now >> http://get.splunk.com/
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
Why delete messages? Unlimited storage is just a click away.
Content-Type: text/html; charset=iso-8859-1
thanks patrick for this this looks very promising i will try this and let me know the statusPatrick Proy <[email protected]> wrote: Hi,You can use regular expressions to select a lot of ports at once (ex :GigabitEthernet 5/* for all the ports of card 5) with the check_snmp_intplugin.Use the C version if you have a big number of interface to use the indexcaching capabilities of the plugin.Info & downloads : http://nagios.manubulon.comRegards,Patrick________________________________De : [email protected][mailto:[email protected]] De la part de rajeshEnvoyé : jeudi 30 août 2007 15:33À : [email protected] : [Nagios-devel] cisco switches and routers physical port
statuswithnagiosHi Guys,I need to monitor cisco switches and routers physical port status.Can i usecheck_ifoperstatus plugin or not.One more question my switch port is having25 or 50 ports how do i check the status.This plugin check all interfaces bydefault or i have to menction each interface.Thanks for your helpBest Regards________________________________________________________________Once upon a time there was 1 GB storage in your inbox. Click here for happyending.l/yahoomail/tools/tools-08.html/> -------------------------------------------------------------------------This SF.net email is sponsored by: Splunk Inc.Still grepping through log files to find problems? Stop.Now Search log events and configuration files using AJAX and a browser.Download your FREE copy of Splunk now
>> http://get.splunk.com/________________________________
...[email truncated]...
