I will try to deploy it on high load test platform, if anyone could test =
it
and give some feedback ...
I will send to version for Nagios3 in a few time.
Yann Jouanin
http://www.yannj.fr
-----Message d'origine-----
De=A0: [email protected]
[mailto:[email protected]] De la part de Thomas
Guyot-Sionnest
Envoy=E9=A0: dimanche 15 juin 2008 18:52
=C0=A0: Nagios Developers List
Objet=A0: Re: [Nagios-devel] Nagios2JSON
Hash: SHA1
On 14/06/08 11:16 PM, Yann JOUANIN wrote:
> I finished coding the XSDJSON backend for Nagios, it works on Nagios 2 =
> (I'm finishing the Nagios3 version).
> Now by enabling USE_XSDJSON, the file status.dat is formatted in JSON=20
> format and the CGI are reading status from this format.
>=20
> For the ones who want to test it, file are available on :=20
>=20
> http://nagios2json.svn.sourceforge.net/ ... DJSON/trun
> k/NAGI
> OS2/
Awesome work!
I made it as a single patch for 2.x-cvs which also includes configure.in
modifications.
After applying the patch, be sure to run "autoconf" then you can =
configure
Nagios with JSON routines with:
./configure --enable-xsdjson
Configure will print the following near the end:
We'll use JSON routines (in xdata/xsdjson.*) for status data I/O...
Then usual make and make install to get everything installed.
I haven't tested it yet (lack of time) but it does build successfully =
with
JSON routines.
Enjoy
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIVUi26dZ+Kt5BchYRAqWcAJ40Eco7ZBoYPZMRb5y++rCSBey8TQCg4k0c
nQv0AzVIcDBDUIeptwoTLGg=3D
=3DoDjl
-----END PGP SIGNATURE-----
