Re: [Nagios-devel] NDOUtils configure error on CentOS x86_64
Ton Voon wrote:
> Does this patch work for you? It uses mysql_config to work out the
> appropriate flags.
> http://altinity.blogs.com/dotorg/2007/0 ... qlcli.html
Ton, the np_mysqlclient.m4
and the patch of
Makefile.in and configure.in works very good. I create a complete patch
for NDOutils-1.4b7, which contains all changes:
http://src.linuxhacker.at/patches/ndout ... tion.patch
and could create a NDOutils with this spec:
http://src.linuxhacker.at/rpmspec/ndoutils.spec
Herbert
