Just upgraded to 3.0b6 from what was a stable 3.0b3 install. Check of
the config files comes back fine, but when starting the deamon I get
after a few moments:
Caught SIGSEGV, shutting down...
I have debug set pretty high but do not see anything jumping out at me
from the logs as a cause (brief snippet of nagios.debug final few lines
below) - is there a known issue, or anything more I can provide? I will
probably roll back to 3.0b3 shortly.
-Matthew
Nagios.debug:
[1194366930.175483] [2048.0] [pid=3D28012] UNHANDLED MACRO #149! THIS IS =
A
BUG!
[1194366930.175499] [2048.0] [pid=3D28012] UNHANDLED MACRO #150! THIS IS =
A
BUG!
[1194366930.175512] [2048.0] [pid=3D28012] UNHANDLED MACRO #151! THIS IS =
A
BUG!
[1194366930.175526] [2048.0] [pid=3D28012] UNHANDLED MACRO #152! THIS IS =
A
BUG!
[1194366930.184171] [016.2] [pid=3D28012] Moving temp check result file
'/usr/local/nagios/var/spool/check
results/checkZWY3uz' to queue file
'/usr/local/nagios/var/spool/checkresults/cRAAfPr'...
[1194366930.192109] [016.2] [pid=3D28011] Moving temp check result file
results/checkbx9gcH' to queue file
'/usr/local/nagios/var/spool/checkresults/cNf2sxz'...
[1194366930.424821] [008.1] [pid=3D27982] ** Event Check Loop
[1194366930.424845] [008.1] [pid=3D27982] Next High Priority Event Time:
Tue Nov 6 09:35:31 2007
[1194366930.424858] [008.1] [pid=3D27982] Next Low Priority Event Time:
[1194366930.424867] [008.1] [pid=3D27982] Current/Max Service Checks: =
7/0
[1194366930.424888] [008.2] [pid=3D27982] No events to execute at the
moment. Idling for a bit...
[1194366930.424897] [001.0] [pid=3D27982] check_for_external_commands()
[1194366930.424909] [064.1] [pid=3D27982] Making callbacks (type 8)...
[1194366930.677126] [008.1] [pid=3D27982] ** Event Check Loop
[1194366930.677142] [008.1] [pid=3D27982] Next High Priority Event Time:
[1194366930.677154] [008.1] [pid=3D27982] Next Low Priority Event Time:
[1194366930.677162] [008.1] [pid=3D27982] Current/Max Service Checks: =
7/0
[1194366930.677172] [008.2] [pid=3D27982] No events to execute at the
[1194366930.677181] [001.0] [pid=3D27982] check_for_external_commands()
[1194366930.677191] [064.1] [pid=3D27982] Making callbacks (type 8)...
[1194366930.928492] [008.1] [pid=3D27982] ** Event Check Loop
[1194366930.928509] [008.1] [pid=3D27982] Next High Priority Event Time:
[1194366930.928521] [008.1] [pid=3D27982] Next Low Priority Event Time:
[1194366930.928530] [008.1] [pid=3D27982] Current/Max Service Checks: =
7/0
[1194366930.928540] [008.2] [pid=3D27982] No events to execute at the
[1194366930.928548] [001.0] [pid=3D27982] check_for_external_commands()
[1194366930.928559] [064.1] [pid=3D27982] Making callbacks (type 8)...
[1194366931.179900] [008.1] [pid=3D27982] ** Event Check Loop
[1194366931.179941] [008.1] [pid=3D27982] Next High Priority Event Time:
[1194366931.179954] [008.1] [pid=3D27982] Next Low Priority Event Time:
[1194366931.179963] [008.1] [pid=3D27982] Current/Max Service Checks: =
7/0
[1194366931.179975] [001.0] [pid=3D27982] handle_timed_event() start
[1194366931.179985] [064.1] [pid=3D27982] Making callbacks (type 8)...
[1194366931.179996] [008.0] [pid=3D27982] ** Timed Event ** Type: 5, Run
Time: Tue Nov 6 09:35:31 2007
[1194366931.180005] [008.0] [pid=3D27982] ** Check Result Reaper
[1194366931.180013] [001.0] [pid=3D27982] reap_check_results() start
[1194366931.180021] [016.0] [pid=3D27982] Starting to reap check =
results.
[1194366931.180197] [064.1] [pid=3D27982] Making callbacks (type 9)...
