Ton> The CVS HEAD version is going to be r1.4. Think this is expected
Ton> mid-August. Can you use just the check_disk executable, if that is
Ton> the only one you required?
Ton> Alternatively, if you want a special df command with r1.3.1, can
Ton> you use ../configure --with-df-command="/bin/df -l"?
Thanks. I went ahead and installed the 20030717 snapshot for now. No
problems so far.
Skip
