Re: [Nagios-devel] [PATCH] Fix some minor memory leaks
--------------060305070808000907040405
Sean Millichamp wrote the following on 02.11.2009 18:39:
> There are some instances where asprintf() are used to construct strings
> but the resulting allocated memory isn't ever free()d. This patch
> (against Nagios 3.2.0) makes sure that the strings allocated by asprintf
> are freed when they are no longer needed.
For the single free statements I fully agree with the implementation.
But for the longer parts I would recommend another way of implementation
- I think your direction is kind of complicated, no offense.
/* generate the query */
asprintf(&api_query,"v=1&product=icinga&tinycheck=1&stableonly=1");
if(bare_update_check==FALSE)
asprintf(&api_query,"%s&version=%s%s",api_query,PROGRAM_VERSION,(api_query_opts==NULL)?"":api_query_opts);
rewritten to
if(bare_update_check==FALSE) {
} else {
does the same, but does not need a second buffer and needs less cycles
as your proposal.
same for
asprintf(&buf,"POST %s HTTP/1.0\r\n",api_path);
asprintf(&buf,"%sUser-Agent: Nagios/%s\r\n",buf,PROGRAM_VERSION);
asprintf(&buf,"%sConnection: close\r\n",buf);
asprintf(&buf,"%sHost: %s\r\n",buf,api_server);
asprintf(&buf,"%sContent-Type: application/x-www-form-urlencoded\r\n",buf);
asprintf(&buf,"%sContent-Length: %d\r\n",buf,strlen(api_query));
asprintf(&buf,"%s\r\n",buf);
asprintf(&buf,"%s%s\r\n",buf,api_query);
if this causes a real memory leak, put it alltogether in one single line
and buffer.
asprintf(&buf,"POST %s HTTP/1.0\r\nUser-Agent: Nagios/%s\r\nConnection: close\r\nHost: %s\r\nContent-Type: application/x-www-form-urlencoded\r\nContent-Length: %d\r\n\r\n%s\r\n",api_path, PROGRAM_VERSION, api_server, strlen(api_query), api_query);
if you need better reading then just reformat the string in the code a bit.
Your opinions on that?
Kind regards,
Michael
DI (FH) Michael Friedrich
[email protected]
Tel: +43 1 4277 14359
Vienna University Computer Center
Universitaetsstrasse 7
A-1010 Vienna, Austria
Content-Type: text/html; charset=ISO-8859-1
implementation. But for the longer parts I would recommend another way
of implementation - I think your direction is kind of complicated, no
offense.
rewritten to
} else {
cycles as your proposal.
same for
asprintf(&
...[email truncated]...
