Re: [Nagios-devel] NSCA using PROCESS_FILE
Any takers (Thomas?) on writing a HOWTO on doing this? I was going to
write up some documentation on doing bulk transfers with NSCA and using
the perfdata files for data output. Since I'm busy with Nagios 3 docs,
this will have to wait a week or so.
If someone wants to write a HOWTO first, I'll ship them an
as-yet-unreleased new Nagios t-shirt that is sure to get me and anyone
who wears it in trouble with the NSA or the Department of Homeland
Security. :-)
Here's what I was going to writeup:
1. Use perfdata file to write passive check information to a file in the
format used by send_nsca
2. Rotate the perfdata file every 60 seconds
3. A cron job runs every minute and pipes the rotated perfdata file to
the send_nsca client.
Bam - bulk data transfer at 60 second intervals. This should help on
both the central and distributed servers. A better performance increase
will happen when the NSCA daemon uses the PROCESS_FILE command when it
receives bulk results from the send_nsca clients.
Gerd Mueller wrote:
> We are already using ocsp sweeper from nagiosexchange. (at Ton: we need ochp as well) This improves the performce. but we still have latencies upto 100 sec. :( So I would call this just a workaround.
> Gerd
> -- Ursprüngl. Mitteil. --
> Betreff: Re: [Nagios-devel] NSCA using PROCESS_FILE
> Von: "Thomas Guyot-Sionnest"
> Datum: 22.02.2007 18:54
> If I were you I'd use Nagios ability to write performance data to a
> file/pipe for ohcp/oscp functionality.
> Send the data to a pipe and have a Perl (Or anything else you want) daemon
> read that pipe and spawn send_nsca processes. One good thing with that also
> is that you could send batch updates since send_nsca can receive multiple
> results in a single run.
> Thomas
>> -----Original Message-----
>> From: [email protected]
>> [mailto:[email protected]] On Behalf
>> Of Gerd Mueller
>> Sent: February 22, 2007 10:56
>> To: Nagios Developers List
>> Subject: Re: [Nagios-devel] NSCA using PROCESS_FILE
>> Am Dienstag, den 20.02.2007, 08:48 -0600 schrieb Ethan Galstad:
>>> Gerd Mueller wrote:
>>>> Hi list!
>>>> Is there a nsca which supports already the Nagios3
>> external command
>>>> PROCESS_FILE? Or any suggestions how to use PROCESS_FILE for
>>>> inter-Nagios-communication with ohcp/oscp?
>>>> Cheers,
>>>> Gerd
>>> NSCA hasn't been modified to use the new PROCESS_FILE
>> command, but I'll
>>> start working on that in the next few weeks. Right now I'm
>>> concentrating on documentation.
>> I really need this new nsca feature. Inter-master-slaves communication
>> in our test environment (about 3000 hosts and livesystem will
>> have much
>> more hosts) via nsca causes the slaves' latency to grow massiv (up to
>> hours!). Whereas a slave with same hardware and same amount of checks
>> but without any ocsp/ochp does nearly nothing (latency >
>> I think the major bottleneck - the serial execution of ocsp/ochp still
>> exists in Nagios3. So Ton's comment on this
>> (http://altinity.blogs.com/dotorg/2006/1 ... ca_da.html) is
>> still true.
>> I expect the new PROCESS_FILE option to avoid this bottleneck. The new
>> nsca client has to be fast enough without any slowing down the slave
>> itself while reading and caching. But I really would appreciate if the
>> main cause of the problem - the ocsp/ohcp executions - could be
>> deserialized.
>> Let me now if I can support the development with testing, coding, ...
>> Gerd
Ethan Galstad,
Nagios Developer
Email: [email protected]
