Re: [Nagios-devel] New Nagios external commands for downtime
On 03/24/2011 05:48 PM, Ton Voon wrote:
> Hi!
> I've just committed into SVN trunk 4 new downtime deletion commands:
> * DEL_HOSTGROUP_HOST_DOWNTIME;hostgroupname *
> DEL_HOSTGROUP_SVC_DOWNTIME;hostgroupname *
> DEL_HOST_SVC_DOWNTIME;hostname *
> DEL_DOWNTIME_BY_START_TIME_COMMAND;starttime;comment
> This allows downtime deletions to work in a master/slave setup,
> because the current mechanism of deletion by id number doesn't work
> in a distributed environment.
It does, but requires the command distribution mechanism to look up
the correct object for itself on the receiving end. Merlin solves
this neatly already.
Even so, I kinda like it.
> A few questions for Ethan: * I assume svn trunk is the right place to
> put this - I note that in branches/ there a feature branches. Can I
> suggest that you use trunk for latest development and create a stable
> branch instead. This is what we do for Opsview and it works very well
> (we tried the other way of development branches but caused a lot of
> unnecessary maintenance)
I agree with this. feature-branches belong in local repositories and
shouldn't be distributed to the global one. That svn makes repeeated
merging damn near impossible is a nuisance we'll have to live with, I
guess, but so long as we maintain them locally they needn't ever hit
svn at all. That's probably for the best.
OP5 AB www.op5.se
on peace.
