On 01/15/2013 10:05 AM, Ton Voon wrote:
> Hi Andreas,
> On 14 Jan 2013, at 10:08, Andreas Ericsson wrote:
>> On 01/14/2013 10:30 AM, Ton Voon wrote:
>>> What I can't work out is how to set the env property in "define command". Can you provide some pointers and assistance?
>> Using a secondary list of key/value vectors. Since commands are usually
>> fewer than 500 and remain pretty static, I'd just use a command->id
>> indexed pointer-to-pointer list of key value vectors.
> I couldn't work out how to create this array. I modelled it on command_ary, but it kept segfaulting when setting this first array element. I'm sure there's a malloc required somewhere, but I couldn't see how command_ary was being initialised. In the end, I've extended the command object to include an env attribute.
That's the forbidden solution. Objects have to be the same size in all compiled
versions.
You have to make an init function for it, allocate the right amount of memory
and then stash the env pointers in a linked list starting at the right slot
in the memory index.
> The next problem is that with an arbitrary list of environment variables, I need to pass this to the worker job creator. I can't see how to extend the wproc_* jobs, but it looks like the nagios_macros are not used. So I propose that we change:
> static int wproc_run_job(worker_job *job, nagios_macros *mac)
> to
> static int wproc_run_job(worker_job *job, char **env)
> Is this acceptable?
Since macros aren't used, yes, although it would be better to pass a
key value vector directly, since we can avoid a ton of strlen() calls
that way and also allow any random values to be passed to the command
calls, which allows for future extensions.
OP5 AB www.op5.se
on peace.
