[Nagios-devel] Notification level Was: COMPLETE: RFE(x2): Service Info/Notify Method On Level
> > NOTIFY METHOD:
> > This allows a service to say that it should only be notified via EMAIL or
> PAGER
> > or BOTH based upon the new state (ok, warn, crit, unknown). If nothing is
> > specified for the service then the default BOTH is choosen (or p,e) which
> is
> > basically what we all know of today.
> > This is kind of cheap as it simply checks the notification command for the
> > $CONTACTPAGER$ or $CONTACTEMAIL$ entry in the raw_command string. If it
> exists,
> > then it's considered that type of notification command (or both) and acts
> > accordingly on it.
> Rather than having Nagios do this centrally, it would be better to
> create a notification script that took the various macros as
> arguments and decided how to notify the contact. This is especially
> true now that there will be six additional address fields for
> contacts in 2.0.
What we really need is a way to be able to say "email on warning" and "page on
critical". We don't want to do this for every service, just some of them. So
if I wanted to do this via a script I would need two different contacts for each
person, as well as two different contactgroups for each set of people, then I
could choose the contact group based upon the service's notification type I
want. Obviously a workaround, but a hack.
Are there any plans to put the notification level closer to the server rather
than just on the contact? Combining this with notification type (page, email)
on the service would make it so that I can clearly fine tune the notification
types for an individual service. Of course, if it's not defined on a service
(making it an optional field) then it could just fall back to the contact's
preference (service's configuration take's precedense).
Just throwing out ideas!
-bk
