--------------000707030309080403000907
the Johannesburg South Africa software freedom day event had a session
where users could work on bugs/features on any project of their choice,
I chose to work on tracker id 86 in the event.
attached are diffs for the lists review, only very basic testing has
been done. any further testing or comments and concerns appreciated.
one area I'm not too sure of, is if waitpid can be interrupted by a
signal and needs to be handled differently to what it currently is.
I'd like to take this opportunity on software freedom day to thank the
nagios project for its work, and the free software community at large.
Content-Type: text/x-patch;
name="checks.diff"
Content-Disposition: inline;
filename="checks.diff"
--- nagios/base/checks.c 2009-08-11 19:29:52.000000000 +0200
+++ checks.c 2009-09-19 23:12:46.000000000 +0200
@@ -338,7 +338,7 @@
int fork_error=FALSE;
int wait_result=0;
host *temp_host=NULL;
- FILE *fp=NULL;
+ FILE *fp=NULL, *chldfp;
int pclose_result=0;
mode_t new_umask=077;
mode_t old_umask;
@@ -346,6 +346,9 @@
double old_latency=0.0;
dbuf checkresult_dbuf;
int dbuf_chunk=1024;
+ int pipefds[2], chldstatus, i;
+ char *chldargs[MAXCHLDARGS];
+ char *s , *p;
#ifdef USE_EVENT_BROKER
int neb_result=OK;
#endif
@@ -771,22 +774,102 @@
/* run the plugin check command */
- fp=popen(processed_command,"r");
- if(fp==NULL)
- _exit(STATE_UNKNOWN);
+ if (!has_shell_metachars(processed_command)){
+ if (pipe(pipefds) == -1){
+ logit(NSLOG_RUNTIME_WARNING,TRUE,"error creating pipe: %s\n",strerror(errno));
+ _exit(STATE_UNKNOWN);
- /* initialize buffer */
- strcpy(output_buffer,"");
+ pid = fork();
+ if (pid == -1){
+ logit(NSLOG_RUNTIME_WARNING,TRUE,"fork error\n");
- /* get all lines of plugin output - escape newlines */
- while(fgets(output_buffer,sizeof(output_buffer)-1,fp)){
- temp_buffer=escape_newlines(output_buffer);
- dbuf_strcat(&checkresult_dbuf,temp_buffer);
- my_free(temp_buffer);
+ if (pid == 0){
+ close(pipefds[0]);
+ if (dup2(pipefds[1],STDOUT_FILENO) == -1){
+ logit(NSLOG_RUNTIME_WARNING,TRUE,"dup2 error\n");
+ _exit(EXIT_FAILURE);
+ if (dup2(pipefds[1],STDERR_FILENO) == -1){
+ s = strchr(processed_command,' ');
+ if (s){
+ *s = '\0';
+ p = s+1;
+ chldargs[0] = processed_command;
+ for(i=1;i= MAXCHLDARGS-2){
+ logit(NSLOG_RUNTIME_WARNING,TRUE,"overlimit args for command %s\n",chldargs[0]);
+ else
+ chldargs[++i] = '\0';
+ else{
+ chldargs[1] = '\0';
+ log_debug_info(DEBUGL_CHECKS,0,"running process %s via execv\n",processed_command);
+ execv(chldargs[0],chldargs);
- /* close the process */
- pclose_result=pclose(fp);
+ close(pipefds[1]);
+ chldfp = fdopen(pipefds[0],"r");
+ if (chldfp == NULL){
+ logit(NSLOG_RUNTIME_WARNING,TRUE,"fdopen error\n");
+ while(fgets(output_buffer,sizeof(output_buffer)-1,chldfp)){
+ temp_buffer=escape_newlines(output_buffer);
+ dbuf_strcat(&checkresult_dbuf,temp_buffer);
+ my_free(temp_buffer);
+ fclose(chldfp);
+ waitpid(pid,&chldstatus,0);
+ pclose_result=WEXITSTATUS(chldstatus);
+ else{
+ log_debug_info(DEBUGL_CHECKS,0,"running process %s via popen\n",processed_command);
+ fp=popen(processed_command,"r");
+ if(fp==NULL)
...[email truncated]...
