Re: [Nagios-devel] Nagios 3.0b7 High CPU Load FreeBSD 6.2
Hi Mike,
please use ldd utility to verify libmap.conf settings:
# ldd /path_to_/nagios
/path_to_/nagios:
libpthread.so.2 => /usr/lib/libc_r.so.6 (0x2cb19000)
if pthread will not be mapped to libc_r, then probably you need to set
correct path to nagios.
If mapping is ok, then I don't know what to suggest.
> here is the output from BEFORE the libmap.conf change
> 98795 nagios RET kse_release -1 errno 22 Invalid argument
> 98795 nagios CALL kse_release(0xbfbfe460)
> here is the output from AFTER the libmap.conf change
> 98688 nagios CALL kse_release(0xbfbfe490)
> 98688 nagios RET kse_release -1 errno 22 Invalid argument
It's strange that BEFORE pid is higher than AFTER, but nevertheless output
is the same.
With best regards,
Andrew.
