I have recently patched out nagios code to increase the freshness
timeout after a restart - I will be adding it to the Altinity blog
within the next few days.
I'll post again when I have had time to do it.
Duncs
On 19 Jun 2007, at 16:49, Michelle Craft wrote:
> I use passive checks for several purposes, but I'd like to start using
> them as a daily heartbeat. The problem is that my nagios server
> restarts
> at least once a day and the freshness timeout is always reset to the
> restart time instead of the last time a passive check was sent. It
> looks
> like the behaviour I would like was present in older versions, but
> changed:
> base/checks.c:
> /* CHANGED 02/25/06 SG - passive checks also become stale, so
> remove dependence on active check logic */
> if(temp_service->has_been_checked==FALSE ||
> program_start>temp_service->last_check)
> expiration_time=(time_t)(program_start+freshness_threshold);
> The freshness example given in the docs (freshness.html) is a daily
> heartbeat. It appears that the above change makes a heartbeat
> impossible
> if the freshness_threshold is ever longer than a reboot cycle.
> I think the only way to fix this is to back-out the change
> (unlikely) or
> add yet another config file option - something like
> freshness_restart -
> and include it in the checks.c expiration_time logic.
> Unless I'm missing something. Has anyone else run into this
> problem or
> found a different work around?
> Michelle
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> Nagios-devel mailing list
> [email protected]
Duncan Ferguson
Opsview - Making Nagios Easier
http://www.altinity.com
Tel: +44 (0)870 787 9243
Fax: +44 (0)845 280 1725
Skype: duncan_j_ferguson
MSN: [email protected]
