[Nagios-devel] View Config and escaped HTML tags
------=_Part_119478_27315708.1175523945110
Content-Disposition: inline
[I tried posting this earlier but no luck. Hopefully it won't double-post.]
The View Config code breaks when trying to display a service's check-command
arguments.
Specifically, doing a CHECK_HTML will often have HTML code such as table
tags in the search string. These tags should be escaped (sanitized) when
displayed so they don't destroy the TABLE syntax in the View Config output.
+ David G. Schlecht
Content-Type: text/html; charset=ISO-8859-1
[I tried posting this earlier but no luck. Hopefully it won't double-post.]The View Config code breaks when trying to display a service's check-command arguments.Specifically, doing a CHECK_HTML will often have HTML code such as table tags in the search string. These tags should be escaped (sanitized) when displayed so they don't destroy the TABLE syntax in the View Config output.
-- + David G. Schlecht
------=_Part_119478_27315708.1175523945110--
